1997 Baja 240 with Mercruiser 454
When key is turned on (not running) it sounds a a loud continuous alarm.
After much searching I find it is related to the oil sensor located at the bottom rear port side where oil is routed to the remote filter from.
When I unplug the lead to this sensor it shuts down the alarm.
Does this indicated a bad sensor or is there something else controling this beyond the sensor?
Thanks in advance
Thanks in advance
