I have read many different forums about the poppet valve or high pressure valve. However, I cannot find one for a 2005 Yamaha T60TLRD. I have looked everywhere. The alarm sounds at low RPM and water starts to flow when I get above 2000 RPM, at idle, no good.
I read that "The valve is closed at low speeds so that the thermostats keep the cylinder head and block temperature close to 140 degrees for better combustion and resistance to fouling plugs and carbon buildup. At high speeds, when internal combustion temps are high, the valve opens and water flows thru the block at a higher rate and the motor water temp stays cooler."
Thanks for your help!!!
