alarm will not beep !
memolesseur
I have a 225 Offshore 1996 Mercury and the alarm that usually beeps before turning on the motor stopped working ! It is a blown fuse ?? Appreciate help on this matter.
Reel Appeal
Re: alarm will not beep !
HI, <br /> Blown fuse,loose wire,bad connection,corrosion,horn went bad,break in wiring,take your pick...Find the horn and trace back wiring to power source.Examine closely,repair anything suspect.With a 12v test light,test the wiring(positive) for voltage at horn.Turn key to ON while checking.Good Luck.<br /> ;)
