Alaska
Mad viking
I have a1996 ciera ext. want to repower. Also all new I/o any suggestions. Motor has 20 psi after I put a load on her n started throwing oil on the portside. Didn't wann blow it up. Out on the ocean in southeast ak.
Re: Alaska
Ayuh,... Welcome Aboard,.... What motor,..?? What outdrive,..??
LippCJ7
Re: Alaska
Yeah, pretty difficult to diagnose anything with the limited info, but 20 psi compression out of any motor isn't good, unless your talking about a weed whacker....
but if you want to repower anyway I think 20psi in your current motors(rings) is a pretty good indication that your boat is ready!
TyeeMan
Master Chief Petty Officer
Re: Alaska
Or are you talking 20 psi oil pressure? Reved up you oughta at least have 40-60 psi, 20 psi at idle is fine when shes warmed up.
20 psi compression pressure = rebuild time.
