les morgan
- May 11, 2007
- 49
installing new motor on boat. Motor was always in forward gear. Pulled lower
unit and turned shaft. I could get the lower unit to shift to neutral. My
queston is when the shifter is in foward the prop should lock in whitch direction. I now have the lower unit in neutral (?)--free wheels in both directions. Should I put the shifter in neutral and install lower unit or put shifter in forward and lower unit in foward?
Les
Les
