Alignment and water pump propeller
4poco
Give you alittle info here. I have a bayliner 175 that i purchased new in 2005. The dealer told me on my last visit that i need to bring it in and do alignment and replace the little propeller in lower unit. (not sure what it called). I am not having any trouble with over heating and runs perfect. Is this something that needs done or is the dealer just trying to sqeeze for alittle cash ? Thanks for your reply and thoughts on this !
Re: Alignment and water pump propeller
Ayuh,... It's 6 years old, 'n Waaay overdue for that service, 'n probably more...
Btw,... It's the Impeller, 'n should be done every couple of years...
4poco
Ok. then service it will be... Just have been told that if it aint broke dont fix it, guess that is not always the case .........
Ayuh,... That's a good line, but...
Without Maintenance, it Will be Broken... ;)
Lotsa Great readin' up in the Adults Only section 'bout it, if yer wantin' to Learn.....
