andrewnzinuk
- May 16, 2012
- 21
Hi
I recently had and engine alignment problem and as a newbie - would like to understand a little more about it. The Volvo Penta dealer said the gimbal bearing needed changing (likley due to growling noise at low rpm). Anyway they changed it and it cost a lot for various reasons. It is an 3.0 GLP-C SX Volvo Penta.
They took the leg off, and it did not come off easily - was very tight and required significant prying. The then found a hole in the bellows and rusty water, along with a rusted gimbal bearing which they showed to me. This boat had passed a pre-purchase inspection by another Vovlo Penta Dealership (a few weeks earlier - with no mention of any mechanical issues - go figure). Anyway ordered new gimbal bearing, bellows kit etc. Long story short could not get gimbal bearing set to the coupler using the alignment tool, engine alignment was a mile out. They showed me - they even moved the motor as much as they could on it's mounts and up and down - they got closer but not all the way into the coupler. They noticed the motor had previoulsy been raised about 12mm on the port side. They ended up lifting the motor and remounting about 1/2 inch to port - the alignment was then perfect. Off course the leg now comes on and off very easily.
I don't believe the gimbal bearing has ever been changed in the boat (2005 four winns 180 H) - has anyone else experienced this before. I was surprised - but not being mechanically minded have to rely on the experts. They mentioned that has a production boat the alignment may have been out off the production line.
I assume remounting your motor to fix an alignment issue is the last resort - but just wondering if any one else has faced this. Cheers Andrew
