alignment
memaw777
I have a 1978 Century 23' 350 engine 260 hp mercruiser. I had the engine replaced the mechanic told me there were no spring lock washers in the rear mounts so when he added these he had to raise the front of the motor over an inch. Seems to me that would put the gimbal bearing at an angle to the motor coupler.He said the motor was perfect align. Would appreciate any input.
Don S
Re: alignment
That's normal. Those springs have to be there, or the alignment will never be right. Plus with a new engine the motor mounts may have been a little off. If he put in the right parts, realigned it and it's now perfect, what's the problem?
memaw777
Re: alignment
Thanks Don I just wanted to get another opinion. I was afraid raising the front that much would put it at an angle to the bearing
memaw777
Re: alignment
Ok I got her home and guess what no gear lube in the out drive no big deal except he ran it at 2500 rpm for 30 minutes. hopefully he didn't put her in gear but still the gears in the top would have been turning. anyone have an opinion as to damage that would come from this
Re: alignment
All the Gears turn in Neutral,........<br /><br />The Shifting is done at the Propshaft..........<br /><br />I'm be Concerned about a 1/2 Hour Run,.... With No Oil..............
Don S
Re: alignment
Not even a question, take it apart and inspect all bearings and gears.
memaw777
Re: alignment
I have the boat home and my alignment tool will go in but it is tight I thought it should go in and out with two fingers. What is the purpose of the spring lock washers are they supposed to make alignment easier somehow. It appears that the front of the motor still needs to go up.If anyone could give me some instruction as to what to do next I would sure appreciate it
bomar76
Re: alignment
Alingment is the least of your worries....as Bondo and Don advised you you need to tear the drive down and see what you FUBAR'ed when it was run for 30 minutes w/o drive lube.
trog100
Re: alignment
if it was the shop or mechanics fault that the drive was run without oil i would scream blue murder and insist that it be stripped and checked for damage..<br /><br />if it was my fault i would optimistically think that it was in neutral under no load.. that all the moving parts still had a liberal coating of oil left over from before the drive was drained and that with a little luck no damage was done..<br /><br />trog
memaw777
Re: alignment
I have the boat home and my alignment tool will go in but it is tight I thought it should go in and out with two fingers. What is the purpose of the spring lock washers are they supposed to make alignment easier somehow. It appears that the front of the motor still needs to go up.If anyone could give me some instruction as to what to do next I would sure appreciate it. I have the drive off and it is being inspected.
Re: alignment
What is the Diagnosis on the Drive that was Run WithOut Oil,..????.......<br /><br />The Spring Washers do 2 things,........<br /><br />1),.... The Most Obvious,.. They're to Space the motor Up.......<br /><br />2),.... They're also a part of the Continuity System,... Or Continuous Grounding of All the Metal Parts of the Drive System........<br /><br />3),.... Yes,.. They Have to be there.........
