Re: All accessories to common ground?
Connecting all the ground wires in some fashion is called bonding. This accomplishes several things when done properly. It controls electrolysis, reduces or eliminates electronic interference, and increases safety. It insures a current path that returns to the battery. To do it "right" includes connecting your devices ground wires, and if very anal, also running a second wire from each device's chassis back to the buss as well.
However, connecting stuff up with three-way crimps only sort-of does the job. A better way is to run something like an 8 or 6 gauge multi-strand copper wire from the "Negative" battery terminal to a buss at the helm or under the console, and run your grounds from your accessories to the buss. Secondly, if it is an aluminum boat,.I also connect the hull in multiple locations bow to stern to the bonding wire.
There will be some who will say that this is overkill and I agree but you won't have any issues either. This opinion goes on the assumption that ALL your devices cumulative amp draw is probably far less than capacity of the buss' ground wire.
