All electrical systems dead except trim on Mercruiser...where to start?
gixxerjim750
One minute everything working correctly. Shut off engine, go to restart, everything dead. Gauges, starter, everything except trim to raise/lower the outdrive. Battery terminals secure and clean. I am thinking ignition switch.
This is on a 1992 Century Mustang with 4.3L Mercruiser I/O....
Please help!
Bt Doctur
locate the slave solenoid and short the 2 large lugs ,motor should spin, next check for a 20A fuse under the dash
th
fishrdan
Check the 50 amp breaker on the engine and the 90(?) amp fuse on the starter. Could also be the ignition switch as you mentioned.
rayaa3
This is a stupid question, but I always like to ask the stupid questions. When you say 'everything is dead' does this include aux items like lights, radio, etc that would ordinarily work w/o engine or ignition being 'on'.
I like the advice of fuses and breakers.
