chicken louie
- Jul 16, 2004
- 94
allmost a boatsman
i have a 1976 erude 55 horse with a jet leg.model #55672e.<br />i have sorted out all my troubles with it thanks largely to support on line.<br />my trouble now is when i was at the boat launch i started it up in water on trailer.<br />warmed it up it had very little water coming out the back,but had a trickle.<br />when i opened the throttle up to test new fuel pump it ran great,but the water stream was not happenig at all.<br />i ran it till i figured it was getting hot @wot.<br />still no water coming out so i shut it down.<br />the flywheel was not hot a little warm,but the side of the motor was fairly hot and the leg was pretty warm.<br />the guy at the boat place says the cooling water comes out of the exhaust (wich i cant verify as its a jet) I dont want to burn up my motor, as i have spent 3000.00 to get it this far.<br />so my ? is how hard is it to drop the jet leg, and is there anything i should watch for with regards to the shaft,gaskets and such.
