Alpha 1 - 5.0L - Idles fine, runs WOT fine for a short time then stalls.
gbarrett
My alpha 1 - 5.0L idles all day without issue, but when I take it out to really run it, she runs great for 10 or 15 seconds then tries to stall. If I bring it back to idle quickly enough it idles great.
My first thought is fuel filter or water sep filter. Before I drop it back in the water - (I'm 20 minutes away from no-wake zone) should I check anything else?
Thanks for being patient with me - I'm new to boats.
Greg
Don S
Re: Alpha 1 - 5.0L - Idles fine, runs WOT fine for a short time then stalls.
Sounds more like a clogged vent or pickup tube in the tank.
Here is a How To, on how to test the boats fuel system for air leaks or plugged fittings etc.
http://forums.iboats.com/showthread.php?t=283269
Ayuh,... My guess is water in the fuel....
Pull the filter, 'n check it's contents...
gbarrett
Problem solved!! Thanks for the help!
I took the fuel pickup tube out of the tank and found the anti-siphon valve attached between the fuel hose and the tube was corroded. I took it out and put a brass fitting in its place and changed the water-separator / filter. I just got back from 3 hours on the water and it ran great!
Again, thanks for the help!
fsjcowboy
Wtg
Ayuh,... Now go get a new Anti-siphon valve....
It's an important Safety feature that should be in-place....
