Alpha 1 bellow replacement
Status
Not open for further replies.
anythingh2o
:) I am replacing the bellows connected to my outdrive due to weathering and cracking. I can get to the exhaust bellows just fine but I can't figure out how to change the cable bellow. Thanks in advance for your help. Stuart
Trent
Re: Alpha 1 bellow replacement
From inside the boat remove the plastic tip from the lower shift cable. Remove the clamp <br /> on the end of the bellows. Unscrew the stainless steel tube, and pull the cable out of the <br /> boat through the boot. Pull core out approximately 1' to protect tip. Lubricate and slide<br /> the new cable bellows up the cable.
anythingh2o
Trent, sorry it took so long to get back with you, my wife found something else for me to do first, but that worked great. Thanks Again for the help. Stuart
Status
