Alpha 1 - Cracked/Weathered Oil Reserve Hose
Hello,
I am about to launch my new to me boat and the only thing a surveyor had called me about (haven't got the full report yet) was a hose on the out-drive. I believe it he called it oil reserve hose. I finally picked it up today and took some pictures. It appears the outer part of the hose is like a neoprene. I just wonder if the inner part of the hose is reinforced with nylon.
Can this wait to be fixed for one more season? This boat hasn't been used in a few years. Is it common for these hoses to have failures? This boat is a 1998 Maxum 2300 SC and Im sure this is probably the original hose. I have attached pictures.
Bt Doctur
Pretty beat hose, should be replaced. Lose the oil, lose the drive
Bt Doctur
Its the hose that supplies gear oil to the drive from the res bottle
poconojoe
That's not good! From the pictures, the bellows look pretty good. I wonder why they didn't replace that hose when they did the bellows? Oh well...
achris
More fish than mountain goat
What is that hose? I don't have it on my gen 1.
Correct. Integrated oil reservoirs only started on the Gen II drives (from 1992)... Reservoirs for earlier drives were a hose connected to the top 'vent' plug hole and the hose ran though a hole in the transom to an oil bottle (some round, some square).
Chris.......
Is it necessary to take drive off or apart to repair this? Reason I ask...one place says they can do itbfor a 100 bucks and they dont have to tear everything apart. Other place says they do and is around 500 dollar range and laughed when i told him the other estimate and said gooood luck to ya.
achris
Drive needs to be removed, but not disassembled. That takes 5 minutes (and if you are skeptical about that time, check out my videos). $500 is over the top. The hinge pins have to come out to allow the bell housing to be moved to gain access, but again, not a long job. After that, the hose can be replaced, and the process is reversed... Given nothing is stuck, then about 2 hours for an experienced tech.
I wouldn't trust a tech that says the drive doesn't need to come off, but I'd also be asking the $500 dollar guy what else you're getting for the $500.... (I'd expect the bellows and shift cable to be replaced for that. ;))
Chris........
