joe average
- Jul 31, 2004
- 9
I just bought a 91 searay 185 with 4.3 mercruiser alpha 1, 500 hours. There are 2 shift problems. When engaging forward gear, if the lever is moved forward to the first detent other than neutral (forward idle speed?) forward gear does not engage, it will click as though close to engaging. Continued movement forward will engage the forward gear but since it is also increasing the throttle it engages heavy. With a bit of practice I have found that I can shift into forward gear with not too much fuss by throwing the lever forward pretty far then immediately returning it to the first forward detent. Functional but not ideal. Second problem: putting the boat into reverse engages immediately and nicely but also immediately begins to close the cutout switch. Any movement of the lever past reverse idle speed closes the cutout switch and of course the engine quits. Again functional, as I don't often use reverse above idle anyway, but not right. I have not done any troubleshooting yet as I thought I could run it by you geniuses first and probably get the answer. thanks Joe
