gamarines2
- Jun 14, 2007
- 102
Folks,
After my spring "sea-trial", I noticed a gear oil leak coming from the starboard side weep hole in the lower unit. On the advice of a forum member, I resealed the upper unit.....bolted it all together; filled her up and noticed no leakage. Hooked up the muffs and ran it to check impeller functionality (replaced pump since I had it apart anyway). A day later, when the driveway was dry, I noticed a small puddle under the outdrive.....GEAR OIL WAS LEAKING OUT OF THIS WEEP HOLE........
Any advice as to what seal could now be leaking would be greatly appreciated.
Jake
Jake
