Alpha 1 gen 1 question
Hi all, thank you in advance for your help. I want to do a full service on my outdrive being that im the new owner of the boat. I have already done u-joints, bellows, gimbal shift cables.. i want to re do the seals on lower unit (weep hole is leaking slowly but leak is a leak) and to want to put in a new pump and impeller.. tracking down the RIGHT kits at the LOWEST cost is grueling and confusing at best.. any links or p/n for the kits i would need would be GREATLY appreciated.. thank you.. outdrive is attached to a 3.0.
Bt Doctur
sierra 18-3320 oem 46-44292A4 this is for the MR,Alpha 1 drive that DOES NOT use the preload spring on the lower driveshaft.
sierra 18-3317 oem 46-57234A3 IS FOR the preload pin
wellcraft-classic210
Master Chief Petty Officer
Just curious -- Are you planning to pressure test the drive ?
That's the best way to ensure all the seals are working properly and pinpoint any problem areas.
Its a good practice after any work.
