blkzoe
- Jan 16, 2013
- 74
Dropped the A1 G1 outdrive to replace the impeller. Drained the gear lube and thought I saw the slighest hint of white in the blue lube. Bubbles or water? Removed the cap from the upper unit to look at the gears. Perfect shape, no corrosion. Remenants of the lube looked blue 100%. Sigh of relief.
Then noted the two "water ports" under the cap. Apparently water circulates all the way to the top of the cap of the upper unit. These cavaties contained sediment I obviously picked up during my shallow water adventure this year (we won't talk about that.) What's the purpose of the water jacked that far up the unit? Cool the gears in the upper? Anybody else get sediment in these cavaties? I cleaned them out the best I could without get any crap in the exposed gear well.
Any thoughts? Ever seen a coolant flow chart for the A1 G1 upper unit?
Thanks in advance.
PS here's an image of the cap the cavaties were found under. I really can't find a good image of the water pocket.
Thanks in advance.
