Re: 1980 Mercruiser MC-1 Water Pump Replacement?
I have twin 485 mercruisers with 1980 Mercruiser MC-1 Outdrives
I am not sure what the replacement pump is I need the part number (I want a complete water pump housing kit w/impeller)
I ordered the sierra 18-3320 but the lower half of the housing did not fit into the bearing. I want the correct pump before I have to pay again!
I am unsure if It has a pre loaded pin (how do I check if it does?)
The outdrive serial number is 5719792
Any help would be appreciated.
Also another quick question 1980 485 mercruisers (3.7L) what oil filter fits this engine.
The Original oil filter PN from Merc is 35-802885Q here is every thing that number crosses to now save your self some change.
Fram: PH8873, PH 30, PH 13, PH5 (the ph5 and ph13 have anti drain back valves in the filter good feature for the 470)
Sierra- 18-7824 BOSCH- 3322
Mallory- 9-57811 CHAMP- PH454
AC Delco- PF454, PF454CL, PF454FCL CARQUEST- 84099
AMS OIL- EA059 CRUSADER- 201104
BALDWIN- B1438 DONALDSON- P550507
AUTOEDGE- AL8873 FIRESTONE- TF454
FLEETGUARD- LF16109
HOPE THIS HELPS
(Right now, I am running the Fram PH-5)
