Alpha 1 gen 2 help is bearing too lose?
Jerry22
I removed the water pump down to the carrier bearing and the bearing seems too lose or that it has too much play. Before I take the drive into a shop can I get some opinions on this bearing? I made a video of it and uploaded to YouTube. See https://youtu.be/f2_yTzdKz64
Ayuh,..... Welcome Aboard,..... When apart, ya, that bearin' is very loose,....
Once assembled, it's fine,....
Bt Doctur
The gears are cut in such a way as to force the driveshaft upwards setting the pinion height.
perfectly normal
Jerry22
You guys are making me feel a lot better. I feared I was going to have to have the entire lower unit re-built. I will proceed to put it back together with all new seals. Thanks.
