Alpha 1 gen 2 mercruiser: what should I use to lube steering cable?
ClaySmoove
I have a ‘98 bayliner Capri with a mercrusier 3.0 alpha what should I use to lube the steering cable it is very stiff. Thanks guys!
CapriBX
From everything I’ve read, just buy new cables. Lubing it is a bandaid fix at best and will only delay the inevitable. High quality cables are a worthwhile investment.
Chris1956
The steering cables on Alphas can bind in the steering tube, at the engine. That can be greased. The balance of the steering cable is sealed.
Quicksilver makes a "Special lube 101" for steering cables. It is the best, but as long as you grease it once a year, any marine grease is fine.
