Got a '91 Alpha one. After initial spring start up I had milky oil in the driveshaft bellows. I pulled drive off, drained oil. I pressure tested at the upper vent hole. 10 lbs of air, ran out immediately thru the driveshaft u joint area. Is there a seal in the bearing carrier of that drive bearing, or does that just seal with the big o rings? Also, do I need to pressure check at the drain hole in lower half to check for leaks down there as well? Thanks for any help.
