Alpha 1 gen 2 reseal
billbayliner
Hi All: Have a question in this exploded view of a alpha 1 gen 2 outdrive, item 31 is a sleeve that seems to slide into the water cooling tube coupling. What purpose does this sleeve serve? Mine was not even pressed into coupler when I split the drive. I am trying to figure out what purpose it serve as I cannot figure it out.
Also, item 34, (sleeve), it shows in the exploded view to be above the seal. There is nothing above my shaft oil seal (36). Is this possible?
http://www.boatfix.com/merc/Techbk/96/96HS2.PDF
BTW, my outdrive year is 1996
Re: Alpha 1 gen 2 reseal
Item 31 is nothing but an Alignment aid, to help you get the water tube in-place....
Can't help you with Item 34....
DHPMARINE
The sleeve connects the pump to the water intake tube above it.
DHP
