Alpha 1 Gen 2 trim pressure line leak - help!
ckaiser
I'm looking at buying a used 1998 Wellcraft 175 SX, Mercruiser 4.3 Alpha 1 Gen 2 with power trim. Apparently one of the pressure lines is leaking fluid down into the bilge. As I ask around, I'm getting different answers as to what needs to happen for me to fix it. I'm a retired auto mechanic and can do just about anything around a vehicle, so I'm not worried about some work.
One marine shop says it's a couple hour job to pull the lines, get them rebuilt or replaced, then put them back in. Disconnect at pump and block, change them out.
Another shop says I have to pull the engine to change these out.
Can anyone give me a definite answer about what I need to do here? Pulling an engine is going to be a deal breaker, or at least a serious price adjustment.
I don't have a service manual yet. Will buy one if I buy the boat, but if anyone has a pdf... ;-)
Thanks!
Charlie
cr2k
Re: Alpha 1 Gen 2 trim pressure line leak - help!
It's still a major pita but you can do it sans pulling the engine. DO NOT FORGET to tie a fish line on each of the hydraulic hoses when you remove them. This will keep it to a one day job without pulling the engine. Don't forget to put the gasket on the block before you attach the new line/s.
Remove the block at the transom where the 4 lines connect, pull block down for access to lines.
Ayuh,... 2, 1/4" nuts, 7/16" 6-point socket...
laying on yer back in the driveway, lookin' straight Up....
Hopefully, it ain't too corroded....
ckaiser
OK, this is starting to look a bit more hopeful. :) Thanks...
Next question is, how do I identify the hoses to get the correct ones? I tried to get a S/N off the outdrive, but the last part of the sticker is worn away.
Should I consider rebuilding these lines or just replace them?
Any purchase location recommendations?
Thanks!
Charlie
Ayuh,... Just replace 'em....
Cruise the parts listings, 'n follow whichever Pump you're got...
There's not alota differences...
