OK this is a total pain, I'm in the middle of re-assembly after bearing and bellows change.
I went with the route of installing the u-joint bellow on the bell housing first since some people said it makes things a bit easier. I got the water hose hooked up and clamped, now the gear lube hose ...this thing is being a pain.
The barb on the bell housing is super close to the bellows, maybe less than 1/16". It's being hard enough to get the hose on there but then even if I do there's no way I'll be able to get a clamp on there. When I took it apart there was a plastic clip, it's reusable, has little teeth that mesh together. I just don't see how I'll be able to squeeze it in there.
Suggestions?
Thanks
Suggestions?
Thanks
