Re: Alpha 1 leaking oil in gimbal housing
Kpkrol, What a switch. Normally you find gear oil in the gimbal housing, want to put in new seals and have to replace the yoke since it has a groove, which would tear up the new seal (like it tore up the old seal). <br /><br />The seal and O-ring should have been replaced when the yoke was installed. It is possible the upper gearcase nut (#16) was not tightened enough? Anyway the seal and oring are avail at any mercruiser dealer for nearly the same price as aftermarket. The yoke was a bit cheaper at the dealer, for some reason!
