CableGuy1978
- Jul 13, 2010
- 66
Hello,
I have replaced my lower shift cable along with a bellows job. I was having some issues with the adjustment, and was unable to find the document I had used a few years back for that procedure. I did however see achris' video on Youtube. Following it exactly, and taking the necessary measurements, chalking the prop as well, I have it adjusted to what I believe is perfect - out of the water. All measurements and allowances are within spec. I did have some issue with the reverse gear meshing, but the small adjustment on the slider pin at the end of the lower shift cable on the shift plate seemed to remedy that.
Where I am at now, in forward gear the prop locks when trying to turn it CCW by hand, and in reverse it locks the other way when turning it by hand. Neutral prop spins freely as well, with no clicking. I didn't put a ton of force on the prop to see if it would slip out when in gear. I have yet to put it int he water and try it under a proper load. After adjusting the cable out of the water, and having the measurements all within spec, how likely is it that further adjustment will be needed? This assuming of course that the drive itself doesn't have any excessive wear. If further adjustment is needed what is the best way to go about it? Since it was set up in forward gear I would imagine that if there is an issue it will be with reverse gear. Figured best to ask the pros instead of wasting time with improper adjustments..
Thanks once again for any advice, and thanks as well to achris for the detailed youtube video.
Jason
Jason
