Re: Alpha 1 no reverse...
Not sure if your shift linkage is the same as mine. I have a pre-alpha Out-drive. Had a somewhat similar problem. Mine was caused by slop in the linkage where the Bell housing and upper unit join, see attached pictures. The part that looks like a ?Shoe? slides into the ?Channel? and is trapped by the sides. That?s why it must be in forward gear when removing or installing the OD. In my case the ?Shoe? had dropped enough so that I did not have a reliable reverse, my fix, of raising the ?Shoe? slightly by installing a Stainless Steel hose clamp, is kind of ?Mickey Mouse?, but it seems to work.. I understand someone else had a problem when the sides of the ?Channel? bent outward, again not trapping the ?Shoe?.
If your Alpha works the same you should be able to see the linkage with the OD raised full up.
Good Luck.
John
