foggyharbour
- May 21, 2008
- 3
I just replaced the prop on my 2005 alpha 1 gen 2. I noticed that when I turned the prop by hand there was a slight scraping noise. If I pull on the prop when turning the noise goes away, there is about 1/8 inch of play (forward/backward) in the prop shaft. I removed the propeller and turned the shaft and the noise is still there. If I put the outdrive all the way down and spin the shaft there is no noise. Any thoughts?
