Alpha 1 rebuild?
Druff1
My brother brought me another Alpha 1 lower unit that he had from his boat, that i bought from him. The main gears are stripped out. I want to rebuild it, so that i will have a spair.
Should i just replace the 2 main gears that are stripped out or buy the whole rebuild kit? Everything else looks to be in good shape.
meesh
Re: Alpha 1 rebuild?
You can get a brand new SEI drive for cheaper than the parts your going to need to rebuild it.
ENSIGN
Why would you pay for a bad drive????
ziggy
have you read service manual #6. the section devoted to lower unit servicing.
this is where i'd start at.
it will likely tell you exactly what to inspect ea. individual part for as far as serviceability of the part in question goes. then you'll be able to decide which parts to replace. the service manual will also let you in on what kind of special mercruiser tools will be necessary to complete the task..
meesh is right about the cost too...
Bt Doctur
The gears don`t normally strip, there heat damaged from a lack of oil. That said, all bearings are subjected to heat damage too. If you lose a roller from a "looks good set" ,that will tear up the new gears.
Ayuh,... When the price of the Tools necessary, combined with the parts Necessary to do your rebuild,...
Is about Twice the Price of a brand new aftermarket lower unit,...
I can't see the economics of rebuilding what's a pile of Scrap...:rolleyes:
On the Bright-side,.... The Bare Case is worth a few bucks to Somebody....
Wise One's Buddy couldn't find 1 Anywhere, at any Price,:eek: a few months ago....
