I have a 1989 Alpha 1 with a 5.7 Merc. I have several problems going on here, all related to shifting. I have attached three photo's showing neutral, Idle and finally open throttle. i also have this on video working.
1. The shifter itself, 90-4200091A Works smoothly except, to engage forward you have to squeeze the trigger and it goes into gear. However, you can pull all the way back to neutral and then into reverse without squeezing the trigger. I guess this would be in the box, like a bad idle lock washer thingy? I have the parts breakdown, and it looks like the two pieces that would could be damaged are the lock ring and the retainer. Guess's?
2. The engine idles fine, around 680 with a photo tach. I can only find the in-gear idle of 650. In gear, it idle's at 650, but when I put it in Neutral, it idles at 850-900. The only way to get it back to 650, is to turn the engine off and restart it. There seems to be no interference in the cables or idle screws. Thoughts?
3.When I am at 650 and shift into gear, I listen for, but do not hear the slight interruption of the switch.With the other things going on, I cant tell if I have a problem there.
So, is this an adjustment issue with a replacement part in the control box or something worse. Intermediate cable? Hopefully I have given enough information to solve this.
Thanks
