paultjohnson
- Jul 29, 2010
- 1,560
When I changed the Impeller on my Alpha 1. Doing routine inspection/cleanup I went to make sure the little drain hole on the lower starboard side of the gear case was clear. It OH SO wasn't. Come to find out the void in front of the shift shaft that drains out of that hole was nearly full of sand, pebbles and crap. At least 6 in deep. It took a considerable amount of digging around with a screwdriver and a little hose rigged up to a wet/dry vac to clear it out. It also explains why water used to dribble out of that drain hole for a day or more after a boat ride. Now it drains like a pee stream for 15-20 secs and its all done. I would think in a worst case scenario, if you used the boat just before a freeze, there may be enough water trapped in there to freeze and crack stuff. [We do that here in Mn
I have been running the boat for 5 plus years with the aft end of the exhaust bellows disconnected. [It had just come off on its own] and I am sure that allowed all that crap in there... Just a little FYI for y'all
