Alpha 1 Top Driveshaft Bearing and race pitted..Does the wholething have to come ap
paultjohnson
Hi I have some pitting in the top driveshaft bearing and race .. I suppose the drive shaft yoke has to come out... Or not ?. The gears look fine and the magnet and gear oil were squeky clean. Is this a DIY job or its it specialized tool intense ?? 86 Alpha 1 Gen 1 Thx!!
Don S
Re: Alpha 1 Top Driveshaft Bearing and race pitted..Does the wholething have to come
The upper needs to come apart. No way to replace that upper bearing without taking it apart.
You also need to check the double bearings on the input shaft, and the lower bearing on the vertical shaft.
paultjohnson
Thx for the quick response Don ;) Damn I was afraid of that sumbch... On the other bearings, do you mean do a visuel check ? Or something more involved ? Im gonna have to look at a diagram to see exactly which bearings you are refering too. I imagine its a tough DIY job ? I have no special merc tools ? Thx
Don S
Yes, just a visual. If they are smooth, everything is ok.
Without a couple of special tools, it's going to be impossible to do.
Here is a link to the OEM service manual, http://www.4shared.com/document/zz_5pj9o/Service_Manual_06.html
Section 3A covers the upper gear box and what is needed.
paultjohnson
You rock Oh Oracle ! Thx ! Glad I checked under the cap. Boat goes to a pole barn tomo for hibernation... Looks like I pull the drive and get er done over the winter Thx again Don ;):):D
coheej
If you do it by the manual, you have to seperate the upper gearcase from the lower and disassemble the upper; pull out a seal and rotate the shaft with a torque wrench to set the preload on the upper bearing.
Look at the manual before you start the project.
paultjohnson
Don Do you have an est on how many hrs I will be looking to be billed. If I R and R and just bring the drive to a shop , best and worst case senerio ? IF you can make a half axx guess ? I can price the parts myself...Thx again
paultjohnson
Good Info- - thanks coheej
Don S
2 to 4 hours.
If you take in the upper gear box, and they pull the input shaft, and reseal the drive (it's already apart and the reseal makes sure they check all bearings) and it's probably due anyway. If they only bearing bad is the upper, it will still need a new race, and reshimmed and rolling torque checked, and all the good stuff.
A lot depends on the shop too. A certified Merc dealer will be faster than one that does 1 a year and has to spend all his time in the manual looking things up.
paultjohnson
Ok... That gives me an idea on what to expect.. Thank you...
