Re: Alpha 1 Trim not operating still
Larry, First you need to determine if it is the cylinders or pump. If you loosen the both pressure hoses at the pump, your drive should go down, under its own weight. Now you can run the pump and see if it puts out. Watch out as the oil can squirt out pretty far. After you find out what is bad and repair it, the system is self bleeding. Just fill the resovoir and cycle the drive up and down several times until all the air is out. Refill the resovoir as necessary.
