Alpha 1 Water Pump
Bayliner1952
Hello,
I own a 1995 Bayliner 1952 Capri Cuddy 3.0LX Alpha 1. "Peachy Keighn"
I just picked up this bad boy. Along with some other toys.
http://www.overtons.com/modperl/pro...pdesc=Upper_Water_Pump_Kit#details_box_holder
I believe it is the wrong pump for my boat. Can someone tell me if the pump for the Gen1 and the Gen 2 Alpha 1's are deferent?
The gentleman at Overtons said it would work, but I don't really want to break apart the lower unit with the possibility that it won't fit.
Thank you for your help. This forum is awesome
Nate
Re: Alpha 1 Water Pump
Hello,
Nate
Ayuh,... That's an Alpha 1 pump kit,...
You need a pump kit for a Gen.II drive,...
No, they're Not the same....
I'll move this to the Merc. I/O forum for ya...
oldjeep
Is your drive serial number in the ranges that they listed?
Bayliner1952
Thanks for moving this Bond-o.
The boat is about 50 miles away, but I will be finding the serial number this evening when I go up to do some work on it.
Thanks for the replies.
Bayliner1952
SN on the Mercruiser is OF473504. Going to give them a call today and get the proper water pump. Thanks again for the help.
