Alpha 1
kpkrol
Can I remove the lower unit without removing the upper unit? I need to replace a water pump. Thanks in advance.
Limited-Time
Re: Alpha 1
The answer is yes if you’re talking about an out drive. But you need to have the correct manual before you start. BTW this should be posted in: Mercruiser, Volvo and OMC I/O or Inboard Engine Problems
