Alpha and bravo 1 props
system-f
I have searched everywhere for this and iboats shows the same spline count and gear case diameter, but:
Will a prop that fits an alpha fit a Bravo One? (I know Alpha and Bravo Two/Three are WAY different)
jaxnjil
Re: Alpha and bravo 1 props
the inner shaft is the same but be careful with the outside diameter. you will hit the anode-trim fin on a alpha if not careful.
you can get a flat one if you have power steering or just break the one you have off.
i have a couple of mirage II vented props that were 15" dia.(i think) after changing the anode to a flat one they worked.
the dealer i bought them from said just break the tab with a hammer. as stated i bought a new flat tab. breaking didnt seem like a good idea.
system-f
That's what I thought. I have already had to trim my trim tab for standard alpha props.
Thanks,
