alpha drive installation help - shift shaft line up question
nateo
Ok so I have the shoe pointing forward but the shift shaft inside the bell housing is turned pointing at about 2:00 and 8:00. The shifter is in forward gear. How do I move shift shift? Doesn't seem to budge with hand.
bspeth
I think you can roll the shift slide outta the way and reposition the shift lever if I am understaning you correctly. Make sure you are at WOT on your remote.The roller has to be in between the U on the slide.
When in forward gear everything should be straight. Was everything shifting as it should before you removed the drive?
Bt Doctur
