Alpha drive or not?
flipbro
Master Chief Petty Officer
Was under the impression my drive was an alpha 1 But after reading some posts im not so sure. Its a 1984 conectected to a 5.7 what drive did merc use on that year. The id tag is long gone!
third times the charm
Re: Alpha drive or not?
Pictures would be helpful. Alpha one was being used by then, almost sure. Anyone with a little better knowledge want to chime in. But again pics are worth a thousand post here:D
What make of engine, mercury, omc, Volvo ?
flipbro
The motor is a merc 5.7. I will try to get picks 2morrow. The outdrive is currently in peaces on my work bench Im in the process of installing a complete seal kit and inspection of every thing.
achris
More fish than mountain goat
1984 was the 'R' drive, a revision of the MC-1. Alpha One didn't start until 1986. (1985 was the 'MR')
The id tag might be gone, but where the tag was the drive serial number should be stamped into the metal... See if you can read that...
Chris......
flipbro
Ok chris thank you i did notice that number stamped in. Is the R drive a respectiful unit or not?
achris
Nothing disrespectful about it... It's a good drive, like all drives, it's as good as it's maintained.
Chris.....
flipbro
Very good thanks 1 last question will the seal kit i ordered 4 a alpha 1 work on this drive aswell?
achris
Very good thanks 1 last question will the seal kit i ordered 4 a alpha 1 work on this drive as well?
Define 'Seal kit'....
Transom seal kit, yes.
Top drive shaft housing seal kit, yes.
Lower gear housing seal kit, yes.
Chris....
flipbro
Sorry. All three are being replaced. Every seal Oring bellow and hose at the transom and drive im doing including gimble bearing! Thanks
