Alpha drive?
Skinny
How do you know which version you have? And what is the difference? I have a 4.3 litre LX and the year us 1996
Thanks
ppagss
Re: Alpha drive?
If you are talking Gen I or II the two easy ways I know of are as follows. If you have a gear lube resevoir for the outdrive in the engine compartment and the speedometer pickup is in the outdrive, you have a Gen II.
oops!
Re: Alpha drive?
if your talking alpha-bravo, i highly doubt that it would be a bravo.
bravo drives are reqired for applications over 300 hp. your 6 isnt that big.
as for alpha gen 1-gen2, its as posted above.
cheers
Re: Alpha drive?
Ayuh,......
The Alpha 1 Gen.IIs came out in 1991,......
I'd Bet that's what your's is..........
achris
More fish than mountain goat
Re: Alpha drive?
Quickest way to tell the two Alphas apart is to look at the point where the upper and lower gearcases meet. If they are held together by 4 exposed and easy to see nuts and bolts, it's a Gen II, if you see just three nuts on studs near the front of the drive, it's a Gen I.
Oops, The V6 is optioned with a choice of Bravo 2 or Bravo 3 drive. Bravo 3 has two counter-rotating props. Bravo 2 has a 20" propeller.
Cheers,
Chris.............
180shabah
Re: Alpha drive?
You could always take the serial number off of the drive and look it up on Merc's website. You'll know exactly what you have, and some great exploded parts views.
