ovwaterlover
- Aug 3, 2012
- 5
I have a 92 Alpha Gen 2. I went to the garage after it being parked overnight and the trim has bled off to where the skeg is on the ground. I hit the bottom on the river idling through a shallow area. I have disconnected and blocked off the trim hoses and it holds position fine. I assume because of the rams are fine it is something inside of the pump. Is this something that can be cleaned, rebuilt, or do I have to replace the whole unit. I have the oildyne 108 pump with the plastic reservoir.
