alpha gen bellows replacement info needed
bolo78910
hello guys , want to change my gen 2 u joint bellows, after i found water in when i haul the boat for the winter. the water cost the gimbal bearing to get rusted up also, after searching the site i relalize it is a pain in the butt job and it is best to just change all the bellows shift cable and bearing at the same time.
now this is my ?? how much u think a mechanic would charge to do the job?? just want to have a idea, thanks much.
bolo78910
Re: alpha gen bellows replacement info needed
just need a ball park figure . thanks
NHGuy
Probably a regular menu item at your local boat repair place. Maybe a $300 to $500 deal? Is that Brooklyn, NY? I do it myself, but I'd guess you can get it done nowadays during the off season a little cheaper. In April, May & June you'll have to get in line to pay $700 or $800 for the same job. Search around and find someone you are comfortable with.
You might also need the universal joints serviced too, depends on how wet they got.
bolo78910
thanks for the info , yes this is brooklyn i kno what u saying i will ask the mechanic to see if he can do it now on a not so cold day, before it gets too busy in the yard.
zbnutcase
I get about $700 if all goes well
