Re: are lower mercrusier units interchangeable
Here is what I have learned through chats with Sterndrive engineering, consulting the Mercruiser Service Manual 14 and counting the teeth on my exploded lower unit.
Not all Alpha 1 Gen2 outdrives share the same lower end.
Thus the ratios are not ONLY in the upper.
- IF you have a 2.00:1 or a 2.40:1 drive the lower unit is geared differently (12 tooth pinion, 24 tooth forwardgear 2:1)
- IF you have a different ratio drive the lower unit is geared with a more common ratio (13 tooth pinion, 21 tooth forwardgear 1.62:1)
Technically the lower ends are interchangeable and you can reprop, but if you want to stick with factory ratios on a 2.00:1 or 2.40:1 drive you will need a lower end with 2:1 ratio.
(I have found out that my lower unit on my 2.00:1 drive that the lower unit was swapped by the previous owner with the other 1.62:1 lower unit, I am curious what will now happen when I reprop with the correct lower unit. )
Paul.
I know this thread is ancient but it's literally what I have now except backwards. The upper is a 1:62 and the lower is a 2:1. Any negative consequences for matching these two?
