Alpha grive swap
Grub54891
I have an 1985 larson,140 mercruiser,Alpha drive.Aquired the boat and checking it over found the drive upper is toast.I have a spare driuve but I belive the gear ratios are different. How bad will this affect my preformance?
Originall drive,ser#:689774 1.98R replacement,0c365322 1.84 R Thank's for any advice.I shure hope I don.t need a new upper!
Grub
Re: Alpha grive swap
Ayuh,.... Ya Might find a prop small enough to work,..... or not....
achris
More fish than mountain goat
Whatever the current prop is, multiple it's pitch by 0.93... That will give you the size of the prop needed to get you back to roughly the same engine speed as before...
If it's 17", then you need to move to a 15"
If it's 19", change to a 17".
Etc....
Chris............
That's it folks.... I'm now, 'one of them'... :D :D :D
