Darol Wester
- Nov 4, 2005
- 157
This is a Mercruiser 260 outdrive lower unit. We had a nasty over heating problem of the port side exhaust hot enough to melt the 3" hose just before the elbow. We removed the lower unit and found that the white tube out the top of the water pump was melted down. The impeller is in good shape. I'm assuming that the pump tubing went first. Any ideas?
Also, this is a 1978 boat and motor. We've replaced the lower end with the Alpha I. On the older unit it shows an O ring at the top of the drive shaft in a grove just below the splines. On the newer unit there is no grove for a ring. There is a place up in the housing that would hold an O ring but we can't find the part listed anywhere. What should be at the top end of the drive shaft?
Would this missing O ring have caused exhaust to blow by and melt the tube?
Thanks
Thanks
