Alpha one Block off plate problem...
chrisf695
So I decided to remove my captains call and in the process of removing the y pipe, one of the bolts broke inside the hole... :mad: The bolt that broke is the upper left one. I was wondering if just using 3 bolts and sealing up with 4200 would be enough to seal up the stainless block off plate i want to use? Few people on my lake said it should hold no problem... but I always like hearing other opinions from you all... :rolleyes:
Don S
Re: Alpha one Block off plate problem...
Flip a coin. Heads it will seal, tails it won't.
I used to have a working crystal ball and could actually see the future, but since it cracked I'm just like everyone else and not able to see into the future.
Howard Sterndrive
fix it right- I forgot to order that seal one time I had the pipe off- I reused the old one which was a bit flat. leaked - and that is a miserable thing to try to troubleshoot with the engine in there. Sleep soundly at night knowing that your boat isn't sinking because of a shortcut.
smokeonthewater
while ur at it smear some blue silicone on it and add some duct tape..........
Seriously... of course you need to remove the broken bolt
MarkSee
A little JB Weld and some Seafoam and that puppy will purrrrrr like a kitten Don........
Mark
