hey everyone i have an 89 alpha on gen 1 with the 1.84:1 gear set. i had the boat on the water and it started vibrating really bad, so i limped it back to the trailer and brought it home thinking maybe the prop loosened up a bit. so i torqued it back down to the 55lbs my manual recommended, and figured while i was at it id pull the drive and check the gimbal and ujoints.. both seemed new.. so i greased up the ujoints and hit all the grease fittings when i put the drive back in. when i fired it up i started hearing a clanking noise every few seconds in neutral.. any guesses? im new to I/O..
