Evinrude Boater
- Jul 6, 2004
- 1,144
When I bought the boat last year the outdrive was corroded so I painted it up and installed a new anode. It corroded again, prop, gear case and rams. I checked continuity between everything on the water side and it was all connected so I cleaned the bottom paint off the hull around the outdrive hoping that was the problem and painted the outdrive again with Mercury Phantom Black enamel. It's still corroding. What should I check next in the water or out of the water?
