taylorjheinzen
- May 21, 2016
- 17
Hey guys, been keeping an eye on my gear oil level this after getting my drive completely resealed last summer,
Leaking only, how much are you leaking?
It won't burn anything, leaking out is the only way the level will drop. If level drops with no external evidence then it may be going into the drive bellows. Removing the drive will show if that is happening. If you wait too long there is a weep hole at the top of the transom assembly inside the boat where any fluid in the bellows that gets up to that level will start coming inside the boat.
I started the summer with the level at it highest and now the level is barely touching the indicator. Maybe have 10 hours on this year so far.
Is this because of specific seal failing?
