Does anyone know about the gear swap from a 1.62 to the 1.84 ratio in an Alpha 1 drive? I have a 1990 Bayliner with the 4.3l engine and have moved the boat from near sea-level to 5000'. <br /><br />What is required? Can I just buy the gear set or do I need the full Upper Gear Rebuild Kit? I am swapping gears because the current ones are damaged and need replacing.<br />Thanks
